Technical Support 6050a2637901-MB-A02
laup
Laptop suddenly stopped working
power switch led lights momentarily when AC is plugged in,
No charging light
AC does not short 19v rail seems good
tested
bios when on board has 3.2v pin 1, 3.2v pin 8.
now pin 5 is 90mv
when i removed bios it now shoots up to 600mv
i dont know if this is relevant or not i cant recal whether there should be voltage there at all?
im not sure if im heading in the right direction?
winbond 25q160vs1g. closet i found below?
No charging light
tested
now pin 5 is 90mv
did you reprogram bios ???
LagaDatorUmea
Lagadatorumea
try post here some more voltages and measurements... we need more information to be able to help you further
