Technical Support AHL50 LA-C701p Power no post
laup
I have a board here that has an issue
I have 4mv to the bios VCC
and 50/200 mv on pin 2 3 also
I have charging light and 3 vol to power button
I have 3.2v to super io vcc i have 3.2 +3VALW_EC pin 124
I have MV from SPI pins 119 120 126 128
would u deem the ENE super io good and PCH bad?
did you reprogram bios and sio before reflow the pch ?????
laup
no i did not
all voltages are exactly the same, i have a BGA machine which was done with bottom heat, so usually wouldnt effect a good chip.
i didnt go the route of programming BIOS or super io as i didnt have votage to the bios
I have the bios removed right now
laup
ok ENE and bios chips can be read and written fine.
after programming ENE with above file i still have no voltage to the bios
as you see on pic 3.3v always and 5v always come after ec_on . check all signal and voltage step by step to find problem .
maybe have problem on 5v always line .
