Technical Support AKAI TV screen double
menum
Hello, I have a TV that came stuck at AKAI logo, I thought is an issue with the firmware, I did the last update but now my image is double.
The TV model is AKTV6536S
I suspect is t-con board but I need some opinions, maybe I can just replace some ic`s that will fix this cost-efficient.
Any help would be great.
Thanks
I think there is a problem with the firmware.
You need to program another firmware. The firmware for the monitor is probably smaller.
You may also be able to select the page size in the settings.
menum
Thanks for your quick answer,
The firmware is taken from the Akai firmware provider.
I could not find any other firmware available.
It would be great if this is only a software issue.
Patrick Ribbsaeter
Lagadatorumea
Double image.. You can google "Ghosting" problem.. Lots of videos on youtube for that
menum
I have tried almost everything, measure the resistors on the screen connectors, all are stable, showing voltage steady, I am unable to find this tcon board, I assume that is at the end of the issue..
Tcon board number is mt5522s.82, I hope I will get some help regarding this,
Thanks
Patrick Ribbsaeter
Lagadatorumea
Thanks
Did u check the CKV, CKVB STV STVP lines?
