Technical Support Asus E502NA Rev 2.1
eoprava
Unnamed
Hello. We have this laptop, it was working, after BIOS flash it don´t turn on. We tried to flash there a backup of original BIOS file, but result is the same. Consumption 0.10A, laptop don´t turn on. We inspected motherboard optically (microscope) and measured all voltages are present. (19V,3.3V, 5V, 1,3V, 1,08V... ) also measured pins on ITE 8995, voltages present. We read on other forum that this laptop has some issue when cleaning ME region, (ME ANALYZER errors) so we think it´ s a BIOS issue after all, we didn´t find any reason that it won´t turn on. But there is an issue, then we plug in battery consumption remains the same (0.10A) after plug in charger. Also the programmer we use is Elnec Beeprog + (Dataman...) it´s not any cheap chineese programmer which most of them do lot of faulty programmings.
And after all we tried thermal camera, but not much results some chips heat up to 36°, that we think is normal operational temperature, (including CPU)
Please do you have any idea what could be the problem ? Did this model had any manufacturer issues?
Thank you for reply
Hello.
Send a BIOS backup to send you a clean ME file.
The current level before turning on should be 0.01 amps. If it is 0.10 amps, test the LDO voltage. LDO power supply is the standby mode of pch and io.(3VL)
eoprava
Unnamed
it 8995
4. PM_SUSC# 3,3V
14. EC_RST# 3,3V
19. SUSB_EC# 3,3V
21.ME_AC_PRESENT_SOC 3,3V
22. BUF_PLT_RST# 0V
26 +3VA_EC 3,3V
67 1.24VSUS_PWRGD 3,3V
68 ALL_SYSTEM_PWRGD 3,3V
69 VCC_PWRGD 3,3V
81 DRAMRST_EC 0V
105 EC SPI_CLK 0V no sig
106.+1.8VSUS 1,8V
108 AC_IN_OC# 0V
109 LID_SW# 3,3V
110 PWR_SW# 3,3V
111 PS_ON 3,3V
112 +3VA 3,3v
117 THRO_CPU#
126 PM_SUSB#
eoprava
Unnamed
CPU PWM CONTROLLER ATK1602GQW
RICHTEK WQFN-28L
P_VCGI_VCC_10 5v
P_VCGI_EN_10 3,3v
VCGI_VR_HOT# 1,81v
P_VCGI_VDIO_50OHM_X1 1,06v
P_VCGI_ALERT#_50OHM_X1 0v
P_VCGI_VCLK_50OHM_X1 1,06v
P_VCGI_VR_READY_10 3,3v
P_VCGI_BST_30 0v
P_VCGI_DH_30 0v
P_VCGI_LX_30 0v
P_VCGI_DL_30 5v
P_VCGI_VIN__10 19v
14 0v
15 5v
P_VCGI_TSEN_10 4.15
P_VCGI_VREF_10 4,15v
P_VCGI_IMON_10 0,5v
P_VCGI_PSYS_10 0v
P_VCGI_ISENP_10 0v
P_VCGI_ISENN_10 0v
P_VCGI_RGND_10 0v
P_VCGI_COMP_10 0v
P_VCGI_FB_10 0v
P_VCGI_VCCSENSE_10 0v
P_VCGI_SET3_10 0v
P_VCGI_SET2_10 0v
P_VCGI_SET1_10 0v
RICHTEK WQFN-28L
P_VCGI_VCC_10 5v
P_VCGI_EN_10 3,3v
VCGI_VR_HOT# 1,81v
P_VCGI_BST_30 0v
P_VCGI_DH_30 0v
P_VCGI_LX_30 0v
P_VCGI_DL_30 5v
P_VCGI_VIN__10 19v
14 0v
15 5v
P_VCGI_TSEN_10 4.15
P_VCGI_IMON_10 0,5v
P_VCGI_PSYS_10 0v
P_VCGI_ISENP_10 0v
P_VCGI_ISENN_10 0v
P_VCGI_RGND_10 0v
P_VCGI_COMP_10 0v
P_VCGI_FB_10 0v
P_VCGI_SET3_10 0v
P_VCGI_SET2_10 0v
P_VCGI_SET1_10 0v
IC inputs are correct. This information exchange IC starts with the processor. It is possible that the processor is broken, or the BIOS has a problem, or the IC itself is broken.
