Technical Support BQ24780S not working ACDRV
lazaro089
Hi I have a Lenovo Thinkpad. Board LA-c421P (no schematics or Boardview available).
The problem is that input mosfets are not driven by ACDRV.
Already changed Charger IC. Both Q1 and Q2. Checked continuity between R4 and R3. Checked C1 and C2 not shorted.
ACDET 2.6V
ACOK 3.3V
VCC 19.8V
REGN 6V
CMSRC 0.424 V
ACDRV 0.262 V
If I jump Adapter VCC @ R0 to ACP, the laptop turns on ok and stays on.
ACDET 2.6V
ACOK 3.3V
VCC 19.8V
REGN 6V
CMSRC 0.424 V
ACDRV 0.262 V
ohm check r ac . reprogram ec NPCE 388NA1DX ( you must jump vcc , acp and after do that you can reprogram ec ). if result is same you must check (ohm check of all resistors and capacity of all cap) all components around of ic charge .
