Technical Support Dell Latitude 3380
pankajbiyani
Hello Dr.bios.com Team
I need Help For Laptop Repair ,I have a problem is dc machine power inject then load 0.011 but Power Button Press then voltage not change
19v present in motherboard or 3/5v not present in motherboard ,how to repair please help me ,which point check do
Thank You
  • Dell Latitude 3380.mp4
    2.9 MB
Prozon
Thank You
what is the motherboard part number.
Patrick Ribbsaeter
Lagadatorumea
Hi,
Start by checking: VCCRTC line, should be 3.3v
second: check the first two MOSFETs and the charging IC working conditions.
Do you know how to check the charging IC pins?
Check if u have voltage on BIOS pin 1(3v3), pin 8 (3v3)..
Related Repair Files
