Technical Support Help repair Asus K43SD Rev 2.2
Dulur
Getting the Asus K43SD Rev 2.2, on the 25Amper psu the laptop can turn on after it is turned off, the psu shows the 30amper laptop can't turn on, measured pins 1 & 8 on the bios ic the voltage is lost but the on/off button is there, is there a solution?
Unfortunately, Hossein Asadolahi is not feeling well ( Because of Covid 19 ) and needs to rest. He will answer you after recovery. Thank you for your understanding
laptop repair havent any solution bro . you must improve your knowledge of electronic . you must check many component , signal and voltage to can guess maybe problem . so without share any information i cant help you correctly i can just say some blan bla to make happy you , that all is bull sheet .
problem in ram slot or onboard ram banks is one of reason of laptop havent pic. so you can disable onboard ram or change it with new one and test this reason .
