Technical Support hp led blink
sultan321
aslam o alakum i have hp dax1bdmb6f0 when power on caps lock led blink 5time long and 3time short what can i do
Test with another RAM first. Also serve the RAM slot.
Test with several BIOS files.
Check the voltage, see if you have all the voltages? Make sure the adapter is healthy and that the adapter is detected by IO. If the voltages disable the graphics normal and test.
