Technical Support HP PAVILION G7
Lindu
Hi, I have a hp pavilion G7 motherboard DAOR53MB6E1 that don't power on, no charging light and on the DC station it was consuming 45a so I noticed that PU12 on the motherboard was hot so I changed it, after charging it still don't power on but this time the power button led was on and PU12 is still heating, any help is appreciated thanks.
Hello
You should check the output power supply. There is probably a problem with the output voltage, which causes the IC to overheat.
