Technical Support Lenovo G50-45 Black screen
biling
Hi, I have a Lenovo G50-45
Power on, slight colour change on screen then back to black
External screen works. Machine boots, fan works etc
Replaced screen with new same error, slight change shade of black then black
Replaced VGA cable exactly same symptom
Replaced with a third screen same symptom
I have never come across this before (usually solved by changing cable or screen)
Any thoughts please
Thanks
Any thoughts please
Thanks
i dont understand very well what your means . do you see display but without backlight ?
pin 1 20.28v
pin 14 0v
pin 16 0.0005v
pin 19 0.17v
pin 20 0v
pin 21 3.366v
pin 23 3.366v
at first : reprogram bios and ec (it8586)
  • DR-BIOS.COM_Lenovo_G50-70=8=ACLU1_ACLU2_NM-A271_Rev_1.0_Bios_Ver_32_it8586e_8mb&128kb_My_Dump.zip
biling
you can program it with universal programmer like SVOD programmer .
Thankyou, I must be missing something. Why would flashing the bios help seeing as the computer works perfectly fine on an external screen. If the bios is corrupted I could just flash the bios supplied by Lenovo for this motherboard. I wouldn't need special hardware to do it?
biling
I have found the H2OFFT-W.exe flash utility used for these motherboards Insyde H2O boards. Can I use this to flash your bin's. It has config file platform.ini
MULTI_FD]
Flag=1
FD#01=ID,Swift3,SU4EA.bin
FD#02=ID,HE4EA,HE4EA.bin and i tried changing these names to your file but no joy
Can you please explain what the bios file you have supplied is going to do?
MULTI_FD]
Flag=1
you must program bios with hardware programmer not with software bro . as i said it before use universal programmer like svod not other one .
