Technical Support Please I need a support here
Ismail-U50
Please I need a support on a challenges am facing concerning one ASUS when I on it, it will on but not display but for like little while the battery let light blinking 3 time so I don’t know how that to do to that please kindly help.
sultan321
replace the ram inshaAllah (by the grace of god) it will ok
Ismail-U50
check your lvds cable or led check 19v 5v and 3v on led
Thanks you for your concern have check Voltage on the boardview through t lvds Which I could found in number 1( pin +3v is present) on the (pin 24 & 25 +3v)t is absent land which it navigate on the boardview as +3vt is present so how do I go about it. Thanks u for your support
sultan321
you are strongly welcome dear
Madonaq
I also have an Asus X53U
MB ver: K53U
Current flowed to the terminal and every part of the motherboard... but it's not coming up.
I've also incubated it, still the same.... whenever I plug in charger it will just blink Amber color once and nothing would happen afterwards
Thanks
sultan321
MB ver: K53U
Thanks
do same as per guideline disconnect ram
Ismail-U50
I just want to appreciate from you Mr. sultan with the guid line you gave me and with boardview you attach also. So I just want to tell the step line I did to make it work by the boardview. So here is it.
1. From the J1701 I try to locate the LCD line voltage of +3volt which is pin 24&25 but the +3volt was not present when I started the work
2. I traced the +3volt line down to C1724 was not present also
3.I turned back the board to locate nest line of join to C1720 +3volt was also not present.
4. Next check was U1701 which was comprises 6 leg but number 1&6 legs suppose to be present with +3volt which 1 leg was absent & leg 6 was present so what I did is I jump pass the +3volt from leg 6 to leg 1 to power the LCD. So what I did is that Mr. sultan I really appreciate Mr. sultan and other member of Dr-Bios.👌👌👌
sultan321
thanks dear brother for your kind worlds my real name is adnan khalid🥰
