Technical Support Plug in not charge into battery section.
CTS1983
chhoeng
My laptop is model inspiron 15-5000 Series, Power on is normal but it is in block battery section has voltage (VIN 12V AND DATA, CLOCK 3V, 3V). BUT NOT CHARGE and battery is still low power. What should i do for this block battery section.
Unfortunately, Hossein Asadolahi is not feeling well ( Because of Covid 19 ) and needs to rest. He will answer you after recovery. Thank you for your understanding
CTS1983
chhoeng
I'm ok brother for replying, pls take care your health. i wish you good luck. Thanks
did you check it with new battery ???
do you check with live os ??
do check battery charging when system is off ??
what is motherboard model number ?
CTS1983
chhoeng
i change battery ready but it is still not charge
i setup window but it's still not charge
check battery section power is normal it is both (Off and Turn On)
Dell Inspiron 15-5000 series (Model:LA-F115P Rev:1.0 (AOO) 2017
CTS1983
chhoeng
  • Video-not-charge battery.rar
