Technical Support Power switch not coming 3.3v
gayan123
My motherboard not coming to 3.3v to power button . Always voltage all is done. We give 3.3v another place that time power on and display coming after off 1 second. I check schematic power switch directly connect to sio that pin also not have 3.3 v
check r880 resistor and volt check both side of resistor .
gayan123
Already come 3.3v one side r880 resister not passing to other side 3.3v oboe have 1v
We replace resister but same matter
disconnect flat of power button from motherboard and check . in this line have only 4 component : r880 , c111 , u13(io) and cn4(socket of power button ) . its so easy . you must check all of them . if you sure c111 and power button mini board havent problem so you must change io with new one .
gayan123
Ok thanks sir I will check
gayan123
We replace sio need to Programing this ? I have svid3 programmer please send me pin connection
Thanks sir sio - ene 3940Q
