File Request turn on and off
Attachment Download Access
i programmed with this file but still it turn on and off with black screen , can u fix this file that i sent ?
bios file can't be fixed for on and off problem!
need to try new bios.
and if you have same result with new file, you should check hardware.
kaihan00001
i know but those files u sent is 32 mb that not compatible with this model , bios file should be 16 mb same as backup and the problem is the bios
that 32MB file is not for this board ! don't think about that. it was mistake from my colleague!
the 16MB file i sent is tested working file and you said there is same problem like old file.
so problem is not bios and you should check hardware.
kaihan00001
this file u sent is 32 MB can u check it again please
i checked everywhere for 435 G8 bios and there is only 32MB bios file !
send your motherboard model so i can make sure .
there is two bios ic on this board
one is 32MB and other is 16MB
  • U366.zip
