i think this problem is related to programmerWhen i used that file to write the bios into the chip during verification process if fails and says "Flash check error address:0h
I used the same programmer to program a bios chip for hp probook 440 g4 and it works fine even the laptop booted up well but with lenovo i keep getting errors, am using a easy pro (EZY 2023+) programmeri think this problem is related to programmer
the file is OK
Have you checked your programmer or Bios
My programmer is working fine, let me check the IC though it was working when i removed it from the motherboard, i just wanted to remove the bios password by flashing it since other methods i used failed.Have you checked your programmer or Bios IC?
Kidr360 , Vahab Hemmati , Salimeh Bolboli , aidhan01 , datbosissss , user54417 , user46825 , sacatecla , gullu , Aung Myo Thant
