alfredposadas09
the first issue is stuck at 5v.... I check PP3V3_G3H and it was shorted line i found q7680 is shorted so i replace the dual mosfet and the short is gone.. I have 20v now and 0.1amp - 0.9amp and i am having 20v on the fuse PPBUS_G3H @ F7000, still no bootup no fan spin.. i dont have PV5G3S_VSW ..
voltages and diode
PP3V3_G3H= 3.3volts & resistance = 3.6k ohms
PV5G3S_VSW =0v & resistance = 3.7k ohms << suspicious since missing voltage
PPBUS_G3H = 20v both side of the fuse
upon checking on CPU coils I found that PP0V95_S0_CPUVCCIO_REG_R L8102 reading is too low i reference on flexbv via diode mode the correct value is 0.124v diode but i am only getting 0.043...
U8110 generated the PP0V95_S0_CPUVCCIO_REG_R and its vin supply is PP5V_G3S_CPUREG_MISC << Maybe this was the reason why I am not getting 5v? is that possible? pls help me
voltages and diode
