Schematic acer aspire vn7-591g wistron hades hbs-860m sv 4pd02w010001 14206 rev-sb schematic
acer aspire vn7-591g wistron hades hbs-860m sv 4pd02w010001 14206 rev-sb 1
BrandWistron Corporation
ModelHades_HBS 860MSB
Motherboard ManufacturerWistron Corporation
Project Code4PD02W010001
Board Number14206
RevisionSB
DateFriday, April 11, 2014
Document NumberA31102
CPU PlatformIntel Haswell
PCH / SouthbridgeIntel Lynx Point
GPU TypeNvidia N15P-GX
Graphics ArchitectureGDDR5
EC / KBCNPCE285PA0DX
Audio CodecALC283
BIOS / SPI Flash8MB SPI Flash
Charging ICHPA02224
RAM TypeDDR3L 1333/1600
RAM ArchitectureSO-DIMM1, SO-DIMM2
LAN ICRealtek RTL8111G(S)
WiFi / WLAN ICWLAN + BT
HDMI Level ShifterPS8201(DB)
Card Reader ICRTS5170(DB)
USB Hub ICCY7C65211
Audio AmplifierALC1001
The Wistron Hades_HBS 860MSB motherboard, documented under project code 4PD02W010001 and board number 14206 revision SB, is built around the Intel Haswell CPU platform paired with the Intel Lynx Point PCH. Graphics processing is handled by a discrete Nvidia N15P-GX GPU with GDDR5 memory. The system uses DDR3L 1333/1600 memory across two SO-DIMM slots. The embedded controller is an NPCE285PA0DX, and the audio codec is an ALC283. An 8MB SPI flash stores the BIOS firmware. Networking is provided by a Realtek RTL8111G(S) LAN controller and a combined WLAN + BT module. The HDMI interface uses a PS8201(DB) level shifter, and a RTS5170(DB) controller manages the card reader. A CY7C65211 USB hub IC and an ALC1001 audio amplifier are also present. The charging circuit is managed by an HPA02224 charger IC.
A: The embedded controller is an NPCE285PA0DX.
Q: What BIOS flash configuration is used?
A: The system uses an 8MB SPI Flash for BIOS storage.
Q: What is the discrete GPU on this motherboard?
A: The discrete GPU is an Nvidia N15P-GX with GDDR5 memory.
Q: What is the charging IC on this board?
A: The charging IC is an HPA02224.
Q: What audio codec and amplifier are used?
A: The audio codec is an ALC283, and the audio amplifier is an ALC1001.
  • Acer_Aspire_VN7-591G=1=Wistron_Hades_HBS-860M_SV_4PD02W010001_14206_Rev-SB.pdf
