acer aspire vn7-592g rayleigh sls 14302-1m 1
The Wistron Rayleigh_SLS motherboard, revision A1, dated August 12, 2015, is built around an Intel Skylake-H CPU platform paired with an Intel PCH-H HM170 southbridge. Graphics are handled by an Nvidia N16P-GX GPU with GDDR5*8 memory. The system uses DDR4-RS memory in two SO-DIMM slots. The embedded controller is a KB9038Q, and the audio codec is an ALC255. The BIOS is stored on an 8MB SPI flash. Charging is managed by an HPA02224 IC. Networking includes a Realtek RTL8111H LAN controller and a WLAN + BT module. A Realtek RTS5170 card reader and a G3703 USB hub are present. The HDMI level shifter is a TPS65982.
Q: What is the EC/KBC model used on this motherboard?
A: The embedded controller is a KB9038Q.
Q: What BIOS flash configuration is used?
A: The motherboard uses an 8MB SPI flash for BIOS storage.
Q: What is the GPU configuration?
A: The discrete GPU is an Nvidia N16P-GX with GDDR5*8 memory.
Q: What is the charging IC on this board?
A: The charging IC is an HPA02224.
| Model | Rayleigh_SLS |
| Motherboard Manufacturer | Wistron Corporation |
| Project Code | Rayleigh_SLS |
| Board Number | Rayleigh_SLS |
| Revision | A1 |
| Date | Wednesday, August 12, 2015 |
| CPU Platform | Intel Skylake-H |
| PCH / Southbridge | Intel PCH-H HM170 |
| GPU Type | Nvidia N16P-GX |
| Graphics Architecture | GDDR5*8 |
| EC / KBC | KB9038Q |
| Audio Codec | ALC255 |
| BIOS / SPI Flash | 8MB SPI Flash |
| Charging IC | HPA02224 |
| RAM Type | DDR4-RS |
| RAM Architecture | SO-DIMM1, SO-DIMM2 |
| LAN IC | Realtek RTL8111H |
| WiFi / WLAN IC | WLAN + BT |
| Card Reader IC | RTS5170 |
| USB Hub IC | G3703 |
| HDMI Level Shifter | TPS65982 |
Intel Skylake-H
PCH-H HM170
PCH / Southbridge
nVidia N16P-GX
Graphics
GDDR5*8
Graphics
KB9038Q
ALC255
HPA02224
Charging / PD IC
DDR4-RS
RTL8111H
LAN Controller
WLAN / BT
WiFi / WLAN
RTS5170
Card Reader IC
G3703
USB Controller
TPS65982
Signal Conditioning IC
Intel Skylake-H
PCH-H HM170
PCH / Southbridge
nVidia N16P-GX
Graphics
GDDR5*8
Graphics
KB9038Q
ALC255
HPA02224
Charging / PD IC
DDR4-RS
RTL8111H
LAN Controller
WLAN / BT
WiFi / WLAN
RTS5170
Card Reader IC
G3703
USB Controller
TPS65982
