Schematic acer compal ls-4221p jala0 rev 1.0 fp board schematic
BrandCompal
Motherboard ManufacturerCompal Electronics, Inc.
Model NameLS4221P
Board NumberLS-4221P
Revision1.0
Date2008/4/10
PCB NameLS4221FPB
Document Number4059L8
EC / KBCTCS4EA-6A-0_BGA27
EC Flash / ROMM95256-WMN6TP_SO8
USB Hub ICMAX4785EXK+T_SC70_5
Crystal12MHZ_16P_DSX840GA
This Compal LS-4221P motherboard, revision 1.0, dated April 10, 2008, is built around the LS4221FPB PCB. The system is managed by a TCS4EA-6A-0_BGA27 embedded controller, supported by an M95256-WMN6TP_SO8 serial EEPROM for EC firmware storage. A MAX4785EXK+T_SC70_5 USB hub IC is present for USB port management. The board utilizes a 12MHZ_16P_DSX840GA crystal for timing reference. The document number for this schematic is 4059L8.
Q: What is the EC/KBC chip used on this motherboard?
A: The EC/KBC is a TCS4EA-6A-0 in a BGA27 package.
Q: What is the EC flash/ROM IC on this motherboard?
A: The EC flash/ROM is an M95256-WMN6TP in an SO8 package.
Q: What USB hub IC is used on this motherboard?
A: The USB hub IC is a MAX4785EXK+T in a SC70-5 package.
  • Acer=Compal_LS-4221P_JALA0_Rev_1.0_FP_Board_DR-BIOS.COM.zip
