acer zejv4 la-a411p r10 0415 cheetah-ct r02 0415
This Compal LA-A411P REV: 1.0 motherboard, branded as Acer Cheetah_CT, is built around the Intel Clover Trail platform. The system management is handled by an ENE IO3737 EC/KBC. The BIOS is stored on a Winbond W25Q32 4Mbit SPI flash. Power management is provided by PSNB5072A1ZNBP power ICs, with charging controlled by a TI BQ24192 charger IC supporting a 1S4P 25Whr battery configuration. The board features 2GB of LPDDR2 memory in a CO-POP architecture. Audio is managed by an ALC5642 codec, and display connectivity includes an HDMI port driven by a Renesas UPD60802A level shifter. Storage and connectivity are supported by a Realtek Sandsisk SDIN5C4-64GB eMMC, a TI TUSB1211 USB hub, and a Realtek LAN controller.
A: The BIOS flash is a Winbond W25Q32 4Mbit SPI NOR flash.
A: The embedded controller is an ENE IO3737.
Q: What is the charging architecture of this motherboard?
A: The charging IC is a TI BQ24192, supporting a 1S4P 25Whr battery configuration.
Q: What type of memory is used on this motherboard?
A: The board uses 2GB of LPDDR2 memory in a CO-POP architecture.
| Brand | Acer |
| Model | Cheetah_CT |
| Motherboard Manufacturer | Compal |
| Project Code | ZEJV4 |
| Board Number | LA-A411P |
| Revision | REV: 1.0 |
| Date | 2013-04-15 |
| CPU Platform | Intel Clover Trail |
| EC / KBC | ENE IO3737 |
| Audio Codec | ALC5642 |
| BIOS / SPI Flash | Winbond W25Q32 |
| BIOS Flash Exact Model | W25Q32 |
| BIOS Flash Capacity | 4Mbit |
| Charging IC | TI/BQ24192 |
| Charger Architecture | 1S4P 25Whr |
| Power IC(s) | PSNB5072A1ZNBP |
| RAM Type | LPDDR2 |
| RAM Architecture | CO-POP |
| RAM Quantity / Slots | 2GB |
| Card Reader IC | Realtek Sandsisk SDIN5C4-64GB |
| USB Hub IC | TI/TUSB1211 |
| LAN IC | Realtek |
| WiFi / WLAN IC | WIFI/BT Combo |
| HDMI Level Shifter | Renesas UPD60802A |
