Schematic apple imac g5 a1058 m39 mlb img5 051-6482 rev c.pdf schematic
BrandApple Computer Inc.
Motherboard ManufacturerApple Computer Inc.
Drawing Number051-6482C
Date08/03/04
RevisionC
CPU PlatformU3LITE
GPU TypeNV18B/NV34
Audio CodecPCM3052
LAN ICBCM5221
USB Hub ICuPD720101
This Apple Computer Inc. schematic, drawing number 051-6482C revision C dated 08/03/04, documents a motherboard based on the U3LITE CPU platform. The system architecture integrates an NV18B/NV34 GPU, a PCM3052 audio codec, a BCM5221 10/100 Ethernet PHY, and a uPD720101 USB 2.0 host interface. The block diagram details HyperTransport, AGP 8X, SATA/150, UATA/133, FireWire A, and PCI interfaces. Main memory is supported via DIMM slots, and graphics frame buffer memory is implemented using DDR SDRAM. The design includes a PULSAR clock generator and a SHASTA core controller for peripheral management.
Q: What is the drawing number and revision of this Apple motherboard schematic?
A: The drawing number is 051-6482C, revision C.
Q: What CPU platform is documented in this schematic?
A: The CPU platform is U3LITE.
Q: What GPU models are referenced in this schematic?
A: The schematic references NV18B/NV34 GPU models.
A: The audio codec is a PCM3052.
Q: What Ethernet PHY is used on this motherboard?
A: The Ethernet PHY is a BCM5221.
  • Apple IMAC G5 A1058=M39 MLB IMG5 051-6482 Rev C.PDF
