Schematic Asus Maximus VI Formula Repair Guide
BrandASUS
ModelMAXIMUS VI FORMULA
Document TypeRepair Guide
Date07/15 2013
AuthorLeilei52_Chen CSC-GRMA
CPU PlatformIntel
GPU TypenVIDIA
PCH / SouthbridgeIntel
The ASUS MAXIMUS VI FORMULA Repair Guide, dated 07/15 2013 and authored by Leilei52_Chen CSC-GRMA, documents the motherboard's block diagram, power flow, and power-on sequence. The platform is based on an Intel CPU and PCH architecture, with nVIDIA GPU support. Key voltage rails include +5V, +5VDUAL, +1.5VDUAL, VTT_DDR, +1.05PCH, VCCIN, +3VSB_ATX, +5VSB_ATX, +12V_CPU, +3VSB, +12V, +1.5VLX, +5V_DUAL_USBKB, +1.05ME, +5V_DUAL_USBKB2, and +3V_DUAL_LAN. Critical power sequencing signals such as S_SRTCRST#, O_PWRBTN#, O_RSMRST#, S_DRAMPWRGD, S_CPUPWRGD, VRMPWRGD, S_SLP_A#, S_SLP_S4#, S_SLP_S3#, O_DPWROK, S_MEPWROK, H_CPURST#, B_ATX_PWROK, S_SLP_LAN#, O_PWROK, O_PCIRST#_PCIEX16_1, O_PCIRST#_PCIEX16_3, and O_PCIRST#_PCIEX16_2 are identified with specific measurement points and diode resistance values to ground.
Q: What is the CPU platform of the ASUS MAXIMUS VI FORMULA?
A: The CPU platform is Intel.
Q: What GPU type is supported on this motherboard?
A: The GPU type is nVIDIA.
Q: What PCH or Southbridge is used on the MAXIMUS VI FORMULA?
A: The PCH / Southbridge is Intel.
  • MAXIMUS_VI_FORMULA_RG.pdf
