Hi,
Please provide me a clean BIOS dump for x910540-007 Microsoft Pro 4 1724. This device doesn't have CPU fan and CPU is Core m3-6Y30.
Thanks
Hi,please check this file
It doesn't work. Please provide me a tested working one.I just did clear me for the last file I sent !
Doesn't work. Even doesn't switch on the system at all. Please don't share any random Surface Pro BIOS. I have uploaded the BAD BIOS as well as all the necessary details. Check it first then provide me a working and clean dump file. ThanksBios - microsoft surface pro 4 pro 4 clear me bios
microsoft surface pro 4 pro 4 clear me 16 mbdr-bios.com
Your colleague already provided this file in post #2. It doesn't work. If you can find a cleaned working BIOS for Core m3-6Y30 CPU and the same MB number I provided, it will work for sure.unfortunately there is no way to build new file with that details for these kind of devices
you just need to try random files to get result:
Please check this website:the file which i sent is tested working file.
i know what you mean, but there is no solution to put or edit a bios file to get fit with the CPU.
