Salim Badakhshan
clevo axioo PJM M1100 Schematic
The Clevo M1110Q/M1110Q-C notebook motherboard, based on schematic version 6-7P-M1114-001, is built around the Intel Pineview 45nm embedded CPU platform paired with the Intel Tiger Point southbridge. The system uses a single DDR3 SO-DIMM0 memory channel. The embedded controller is an ITE IT8502E in a 128-pin LQFP package. Audio is handled by a VT1812 Azalia codec. Networking and storage connectivity is provided by a JMC251/JMC261 LAN IC, while the card reader function is managed by a JMB261 IC. Thermal monitoring is performed by an EMC1402 sensor, and the system clock is generated by an SLG8SP510T clock generator.
Q: What is the board number for the Clevo M1110Q motherboard?
A: The schematic is based upon version 6-7P-M1114-001.
A: The embedded controller is an ITE IT8502E in a 128-pin LQFP package.
A: The audio codec is a VT1812.
Q: What LAN and card reader ICs are used on this motherboard?
A: The LAN IC is a JMC251/JMC261, and the card reader IC is a JMB261.
| Brand | Clevo |
| Model | M1110Q / M1110Q-C |
| Motherboard Manufacturer | Clevo |
| Board Number | 6-7P-M1114-001 |
| CPU Platform | Intel Pineview 45nm |
| PCH / Southbridge | Intel Tiger Point |
| EC / KBC | ITE IT8502E |
| EC/KBC Package | 128 pins LQFP |
| Audio Codec | VT1812 |
| RAM Type | DDR3 |
| RAM Architecture | One Channel SO-DIMM0 |
| RAM Quantity / Slots | 1 |
| LAN IC | JMC251 / JMC261 |
| Card Reader IC | JMB261 |
| Thermal Sensor | EMC1402 |
| Clock Generator | SLG8SP510T |
