clevo m360h-d02 2843 1
The CLEVO M360H motherboard, documented under board number 71-M36H0-001 revision 1.0, is built around the Intel Banias processor platform paired with the Intel ICH4 southbridge. Graphics are handled by the Montara-GM LGMCH in a 732uFCBGA package. System memory consists of two DDR SDRAM SO-DIMM sockets. The embedded controller is a HITACHI H8S microcontroller. Audio is managed by an ALC202 codec, while networking is provided by a Realtek RTL8100B LAN IC. A CardBus ENE-1410 controller is present, and wireless connectivity is supported via a MiniPCI socket. The system block diagram indicates a dedicated charger IC for power management.
Q: What is the board number and revision for the CLEVO M360H?
A: The board number is 71-M36H0-001, revision 1.0.
Q: What EC/KBC is used on the CLEVO M360H?
A: The embedded controller is a HITACHI H8S.
A: The audio codec is an ALC202.
Q: What LAN IC is used on the CLEVO M360H?
A: The LAN IC is a Realtek RTL8100B.
| Brand | CLEVO |
| Model | M360H |
| Motherboard Manufacturer | CLEVO CO. 藍天電腦 |
| Board Number | 71-M36H0-001 |
| Revision | 1.0 |
| Date | Friday, September 24, 2004 |
| CPU Platform | Banias |
| PCH / Southbridge | INTEL ICH4 |
| GPU Type | Montara-GM |
| Graphics Architecture | Montara-GM LGMCH 732uFCBGA |
| EC / KBC | HITACHI H8S |
| Audio Codec | ALC202 |
| LAN IC | RTL8100B |
| RAM Type | DDR SDRAM |
| RAM Architecture | SO-DIMM0, SO-DIMM1 |
| RAM Quantity / Slots | 2 |
| Card Reader IC | ENE-1410 |
| WiFi / WLAN IC | WirelessLan MiniPCI SOCKET |
| Charging IC | Charger |
