Usually, in some laptops, this happens for the first time after the BIOS is cleared, and in subsequent cases, it does not happen again.
I think there is a problem with the cmos memory inside the chip, or the standby voltage that enters the chip from the battery is interrupted on the way.
Usually, 3 volts from the battery passes through the resistor and diode and enters the chipset.
