- Device Model
- LATITUDE
FREEZE DEVICE- DELL LATITUDE 3420
I need disable absolute mode
WITH THIS BIOS TURN ON, BUT IT DOES NOT RECOGNIZE THE SSDFREEZE DEVICE- DELL LATITUDE 3420
there should be another file on the motherboard
because while i trying to fix the bios it says the bios pattern is not full
please check ino entiendo hay hay dos BIOS y ninguna puedes hacer
I don't understand, there are two BIOS versions and you can't do either of them.there should be another file on the motherboard
please check it
your file have openning error bro !I don't understand, there are two BIOS versions and you can't do either of them.
That motherboard only has one BIOS.your file have openning error bro !
But it says it's 12 mg and mine says 32 mg.this is latest update bios file for this device and every issue related to bios is solved :
MB*But it says it's 12 mg and mine says 32 mg.
bro! it seems you not even downloaded itBut it says it's 12 mg and mine says 32 mg.
i already sent the file brother!Please I'm waiting
