Dell latitude 3520 - Cyborg -L15 MB TGL 203070-1 Schematic
This Wistron Cyborg TGL motherboard, board number A41105 revision A00, is built around the Intel Tiger Lake U platform. The system utilizes a discrete NVIDIA N17S-G5 GPU with GDDR5 memory and supports dual-channel DDR4 SODIMM memory across Channel A and Channel B. The embedded controller is a Microchip MEC1515H-D0-I, and the audio codec is a Realtek ALC3204. The charging IC is an ISL9538C. For BIOS storage, the CBG-NV variant uses a 32M SOIC 8 non-RPMC flash, while the CBG-L variant uses a 32M WSON RPMC flash. Networking is handled by a Realtek RTL8111H LAN IC and CNVi wireless. The HDMI interface uses a Parade PS8719 level shifter, and the card reader is a Realtek RTS5144.
Q: What BIOS flash configurations are used on this motherboard?
A: The CBG-NV variant uses a 32M SOIC 8 non-RPMC flash, while the CBG-L variant uses a 32M WSON RPMC flash.
A: The embedded controller is a Microchip MEC1515H-D0-I.
Q: What is the charging IC on this motherboard?
A: The charging IC is an ISL9538C.
Q: What GPU is used on this motherboard?
A: The discrete GPU is an NVIDIA N17S-G5 with GDDR5 memory.
The Wistron Cyborg-N/V/L 14/15_TGL-U motherboard, project code Cyborg TGL and board number CBG X01 N revision X01, is built around an Intel Tiger Lake U CPU platform. Graphics are handled by an NVIDIA N17S-G5 GPU with GDDR5 VRAM. The embedded controller is a MICROCHIP MEC1515H-D0-I. Audio is provided by a REALTEK ALC3204 codec. The BIOS SPI flash is a 32M SOIC 8 non-RPMC configuration for CBG-NV variants, with a compatible 32M WSON RPMC option for CBG-L. System memory consists of two DDR4 SODIMM slots. The charging IC is an ISL9538C. Wired networking uses a Realtek RTL8111HS LAN IC, while wireless connectivity supports CNVi. The HDMI level shifter is a PARADE PS8719, and the card reader controller is a Realtek RTS5144.
Q: What BIOS IC models are used on this motherboard?
A: The CBG-NV variant uses a 32M SOIC 8 non-RPMC SPI flash. The CBG-L variant uses a compatible 32M WSON RPMC SPI flash.
A: The embedded controller is a MICROCHIP MEC1515H-D0-I.
A: The motherboard uses two DDR4 SODIMM slots.
This Wistron Corporation Cyborg_IO_BoardSA, revision SA, is an I/O board designed for the TGL-H RTX platform under project code QRQY00001063, dated 2020/07/28. The board integrates a Realtek RTS5144-GR-GP card reader IC supporting a standard SD card slot via USB 2.0, and a Parade PS8719 USB 3.0 redriver for 5Gbps operation. The block diagram also indicates a USB 3.2 Gen1 Type-A port and a fingerprint reader connection. The schematic includes detailed layout notes for critical signals such as SDREFG, RREF, and power rails 3D3V_CARD_S0 and V18.
Q: What is the project code and board number for this I/O board?
A: The project code is QRQY00001063 and the board number is Cyborg_IO_BoardSA, revision SA.
Q: What card reader IC is used on this board?
A: The card reader IC is a Realtek RTS5144-GR-GP.
Q: What USB redriver is present on this board?
A: A Parade PS8719 USB 3.0 redriver is used for 5Gbps operation.
| Brand | Cyborg |
| Model | N/V/L 14/15_TGL-U |
| Motherboard Manufacturer | Wistron Corporation |
| Project Code | Cyborg TGL |
| Board Number | A41105 |
| Revision | A00 |
| Date | 2021-01-07 |
| CPU Platform | Intel Tiger Lake U |
| GPU Type | NVIDIA N17S-G5 |
| Graphics Architecture | GDDR5 |
| dGPU Chip Number | N17S-G5 |
| EC / KBC | MEC1515H-D0-I |
| EC/KBC Package | MICROCHIP |
| Audio Codec | REALTEK ALC3204 |
| BIOS / SPI Flash | 32M SOIC 8 / NON RPMC (CBG-NV); 32M WSON / RPMC (CBG-L) |
| Charging IC | ISL9538C |
| RAM Type | ddr4-sodimm/"]DDR4 SODIMM[/URL] |
| RAM Architecture | Channel A, Channel B |
| RAM Quantity / Slots | 2 |
| Card Reader IC | Realtek RTS5144 |
| LAN IC | Realtek RTL8111H |
| WiFi / WLAN IC | CNVi |
| HDMI Level Shifter | PARADE PS8719 |
| Model | Cyborg-N/V/L 14/15_TGL-U |
| Board Number | CBG X01 N |
| Revision | X01 |
| Date | 2020-08-20 |
| BIOS / SPI Flash | 32M SOIC 8 / NON RPMC (CBG-NV) |
| BIOS Flash Exact Model | 32M SOIC 8 / NON RPMC (CBG-NV) |
| BIOS Flash Capacity | 32M |
| BIOS Flash Package | SOIC 8 (CBG-NV) |
| Compatible BIOS IC Models | 32M WSON / RPMC (CBG-L) |
| RAM Type | DDR4 |
| RAM Architecture | SODIMM |
| LAN IC | Realtek RTL8111HS |
| Model | Cyborg_TGL-H RTX_IO Board |
| Project Code | QRQY00001063 |
| Board Number | Cyborg_IO_BoardSA |
| Revision | SA |
| Date | 2020/07/28 |
| CPU Platform | TGL-H |
| Card Reader IC | RTS5144-GR-GP |
| USB Hub IC | Parade PS8719 |
A41105
Board Number
Intel Tiger Lake U
NVIDIA N17S-G5
Graphics
GDDR5
Graphics
N17S-G5
Graphics
MEC1515H-D0-I
ALC3204
ISL9538C
Charging / PD IC
DDR4 SODIMM
RTS5144
Card Reader IC
RTL8111H
LAN Controller
CNVi
WiFi / WLAN
PS8719
Signal Conditioning IC
CBG X01 N
Board Number
BIOS / EC Flash
DDR4
RTL8111HS
LAN Controller
QRQY00001063
Project Code
TGL-H
RTS5144-GR-GP
Card Reader IC
PS8719
USB Controller
A41105
Board Number
Intel Tiger Lake U
NVIDIA N17S-G5
Graphics
GDDR5
Graphics
N17S-G5
Graphics
MEC1515H-D0-I
ALC3204
ISL9538C
Charging / PD IC
DDR4 SODIMM
RTS5144
Card Reader IC
RTL8111H
LAN Controller
CNVi
WiFi / WLAN
PS8719
CBG X01 N
Board Number
BIOS / EC Flash
DDR4
RTL8111HS
LAN Controller
QRQY00001063
Project Code
TGL-H
RTS5144-GR-GP
Card Reader IC
PS8719
USB Controller
