File Request DELL LATITUDE 7320 GDC31 PND955X- remove password
jayson1985
Hello,
I tested the BIOS that you made available, but they do not work with my laptop. The laptop turns on then turns off, and then I have the 3 RGB colors. I reverted to my original BIOS, and the laptop boots correctly, so it is not a hardware problem. Is it possible to remove the BIOS password and to change the serial number?
thanks
  • GD25B256D@WSON8_7320.BIN
Salimeh Bolboli
Hello,
thanks
  • Dell 7320.zip
jayson1985
Hello,
Thank you for your response; however, the file does not work, the laptop won't turn on anymore. So, I reverted to the old BIOS, and now my laptop boots correctly into the BIOS.best,
jayson1985
No, with your modified BIOS, I get nowhere. Only the original BIOS works. I have tested the other BIOS; 7320 does not work with my motherboard.
Is it because the firmware is signed that it poses a problem?
Wait, I'm completely lost now. When I click on the link, I'm redirected to a blank request. I assumed you were asking me to make a new request... I created a new request and see that it has been deleted. Please be clearer in your responses.
  • LA-K371P test ok.zip
jayson1985
I posted a message that said this and I had added this image:
Your BIOS seems to work because I was able to boot into the BIOS, however, there is still a BIOS password.
