dell vostro 3450 zal50 zal60 la-b072p rev 0.1
This Dell/Compal Marble Falls Discrete motherboard, project codes ZAL50 and ZAL60, uses board number LA-B072P revision 0.1 dated 2013-10-03. The platform is built around an Intel Broadwell ULT-U processor in a BGA 1168 package. Discrete graphics is handled by an N15S-GM GPU in a GB2B-64BGA 595 package. System memory consists of dual-channel DDR3L via two DDRIII-L-DIMM X2 slots supporting up to 8GB at 1600 MHz. The embedded controller is an SMSC KBC MEC5085. Audio is provided by an ALC3234 codec. The BIOS is stored on an SPI ROM. Connectivity includes an RTL8111G LAN IC, WiFi/BT4.0, an RTS5176 card reader, and an IT6513FN DP to CRT level shifter for HDMI output.
Q: What is the board number and project code for this motherboard?
A: The board number is LA-B072P, and the project codes are ZAL50 and ZAL60.
A: The embedded controller is an SMSC KBC MEC5085.
Q: What is the discrete GPU model on this motherboard?
A: The discrete GPU is an N15S-GM in a GB2B-64BGA 595 package.
Q: What memory architecture does this motherboard support?
A: It supports dual-channel DDR3L memory via two DDRIII-L-DIMM X2 slots, with a maximum of 8GB at 1600 MHz.
| Brand | Dell / Compal |
| Model | Marble Falls/ Discrete |
| Project Code | ZAL50, ZAL60 |
| Board Number | LA-B072P |
| Revision | 0.1 |
| Date | 2013-10-03 |
| CPU Platform | Intel Broadwell ULT |
| CPU Model | Intel Broadwell ULT-U Processor BGA 1168 |
| GPU Type | N15S-GM |
| Graphics Architecture | GB2B-64BGA 595 |
| EC / KBC | SMSC KBC MEC5085 |
| Audio Codec | ALC3234 |
| BIOS / SPI Flash | SPI ROM |
| RAM Type | DDR3L |
| RAM Quantity / Slots | DDRIII-L-DIMM X2 |
| Card Reader IC | RTS5176 |
| LAN IC | RTL8111G |
| WiFi / WLAN IC | WiFi/BT4.0 |
| HDMI Level Shifter | IT6513FN |
ZAL50
Project Code
ZAL60
Project Code
LA-B072P
Board Number
Broadwell-ULT
CPU Model
N15S-GM
Graphics
GB2B-64BGA 595
Graphics
MEC5085
ALC3234
DDR3L
RTS5176
Card Reader IC
RTL8111G
LAN Controller
WiFi/BT4.0
WiFi / WLAN
IT6513FN
Signal Conditioning IC
ZAL50
Project Code
ZAL60
Project Code
LA-B072P
Board Number
Broadwell-ULT
CPU Model
N15S-GM
Graphics
GB2B-64BGA 595
Graphics
MEC5085
ALC3234
DDR3L
RTS5176
Card Reader IC
RTL8111G
LAN Controller
WiFi/BT4.0
WiFi / WLAN
IT6513FN
