Salim Badakhshan
Dell Wistron Hellcat 13 19721 Schematic
The Wistron JEDI 13" (Project Code HELLCAT 13", Board Number 19721, Revision DVT1) is a Comet Lake-U based platform documented under schematic number A31106. The system uses UMA-only graphics with LPDDR3 memory configured as 2Rx16 memory down across two channels. The EC/KBC is a Microchip MEC1515, and the BIOS is stored on a 16MB+8MB Quad Read Flash ROM. Audio is handled by a Realtek ALC3254 codec. The charging solution uses a Cypress CCG5 C controller. Thermal monitoring is provided by a Nuvoton NCT7718W sensor. The card reader is a Realtak RTS5144, and the HDMI interface uses a Parade PS186 level shifter. The system also integrates a Parade PS8762D USB hub and a TPM solution combining Nuvoton NPCT750 and ST ST33HT.
Q: What is the BIOS flash configuration on this motherboard?
A: The BIOS is configured as a 16MB+8MB Quad Read Flash ROM.
A: The EC/KBC is a Microchip MEC1515.
A: The system uses LPDDR3 memory in a 2Rx16 memory down configuration across two channels (Channel A and Channel B).
Q: What is the graphics configuration of this motherboard?
A: The motherboard is UMA only, with no discrete GPU installed
| Model | JEDI 13" |
| Motherboard Manufacturer | Wistron Corporation |
| Project Code | HELLCAT 13" |
| Board Number | 19721 |
| Revision | DVT1 |
| Date | 2019-10-27 |
| CPU Platform | Comet Lake-U |
| Document Number | A31106 |
| EC / KBC | MEC1515 |
| EC/KBC Manufacturer | MICROCHIP |
| Audio Codec | ALC3254 |
| Audio Codec Manufacturer | Realtek |
| BIOS / SPI Flash | 16MB+8MB Quad Read Flash ROM |
| Charging IC | CCG5 C |
| Charging IC Manufacturer | Cypress |
| RAM Type | LPDDR3 |
| RAM Architecture | 2Rx16 Memory Down |
| RAM Quantity / Slots | 2Rx16 Channel A, 2Rx16 Channel B |
| Thermal Sensor | NCT7718W |
| Thermal Sensor Manufacturer | NUVOTON |
| Card Reader IC | RTS5144 |
| Card Reader IC Manufacturer | Realtak |
| LAN IC | Harrison peak2 |
| WiFi / WLAN IC | Harrison peak2 |
| HDMI Level Shifter | PS186 |
| HDMI Level Shifter Manufacturer | Parade |
| TPM | NPCT750 & ST33HT |
| TPM Manufacturer | NUVOTON & ST |
| USB Hub IC | PS8762D |
| USB Hub IC Manufacturer | Parade |
| GPU Type | UMA only installed |
| Graphics Architecture | UMA only |
19721
Board Number
Comet Lake - U
MEC1515
ALC3254
CCG5 C
Charging / PD IC
LPDDR3
NCT7718W
Thermal / Fan Control
RTS5144
Card Reader IC
HARRISON PEAK2
LAN Controller
Harrison peak2
WiFi / WLAN
PS186
Signal Conditioning IC
PS8762D
USB Controller
UMA only installed
Graphics
UMA (only)
Graphics
19721
Board Number
Comet Lake - U
MEC1515
ALC3254
CCG5 C
Charging / PD IC
LPDDR3
NCT7718W
RTS5144
Card Reader IC
HARRISON PEAK2
LAN Controller
Harrison peak2
WiFi / WLAN
PS186
PS8762D
USB Controller
UMA only installed
Graphics
UMA (only)
Graphics
