Technical Support FX504G DABKLGMB8D0 REV D
afonso
tafonso
Enterprise
HI can someone help:
First, board no power, mosfet ic short
after replace mosfet CPU, MB turn on, have all voltages: 3,3v ,5v, 1,05 chipset, 1,2v memory, graphic etc, but no image
so, when i turn on, i have voltage on cpu, and after past 3 min. this voltage desapear.
what i do for to try repair this mb?
Thanks,
Which MOSFET was burnt?
Are the voltages normal now?
It is possible that the system has an image delay. Be sure to wait 5 minutes and check the amount of current and voltage of the board.
Did you program the BIOS?
Did you service and replace the RAMs?
afonso
tafonso
Enterprise
Sorry I made a mistake with another equipment, there was a shorted capacitor and the track damaged in the 5v line of the mosfet driver isl95808 of the cpu. all voltages are fine, but after 1 or 2 minutes the cpu voltage goes to 0 and the others stay the same. already replaced ram and bios. any sugest?
Related Repair Files
