Salim Badakhshan
Gigabyte B460M D2VX SI Rev 1.0 1.1 Schematic
The Gigabyte B460M D2VX SI motherboard, revision 1.0, is built around the Intel LGA1200 (Comet Lake) CPU platform with a B460 PCH. The board utilizes an ITE 8686 LPC I/O controller (ITE8688) for EC/KBC functions. Audio is handled by a Realtek ALC887 codec, and networking is provided by a Realtek 8111G LAN IC. The system BIOS is stored on a 128M SPI flash. Memory architecture consists of two DDR4 DIMM slots. Power management includes ISL95866 VCCGT-IRON, ISL95866 VCORE-IRON, and ISL95866 PWM-IRON charging ICs, alongside RT8068A_VPP, RT8237_DDR_BEAD, RT8237_PCH-BEAD, and RTD2168 DP to VGA converter power ICs. The board features integrated graphics from the CPU.
Q: What is the BIOS flash capacity on this motherboard?
A: The BIOS flash capacity is 128M.
A: The EC/KBC controller is an ITE 8686 LPC I/O (ITE8688).
A: The audio codec is a Realtek ALC887.
Q: What LAN IC is used on this motherboard?
A: The LAN IC is a Realtek 8111G.
The Gigabyte B460M D2VX SI motherboard, revision 1.1, is built around the Intel LGA1200 (Comet Lake) CPU platform with a B460 PCH. The system uses DDR4 memory across two DIMM slots. The embedded controller is an ITE 8686 LPC I/O. Audio is handled by a Realtek ALC887 codec, and networking is provided by a Realtek 8111G LAN/WLAN IC. The BIOS is stored on a 128M SPI flash. Power management includes ISL95866 controllers for VCCGT, VCORE, and PWM, alongside RT8237 and RT8068A_VPP regulators. The HDMI level shifter is an RTD2168, and the card reader IC is an IT8892E.
A: The ITE 8686 LPC I/O is used as the embedded controller.
Q: What is the BIOS flash capacity?
A: The BIOS is a 128M SPI flash.
Q: What audio codec is used?
A: The Realtek ALC887 audio codec is used.
Q: What LAN IC is used?
A: The Realtek 8111G is used for LAN.
| Brand | Gigabyte Technology |
| Model | B460M D2VX SI |
| Motherboard Manufacturer | Gigabyte Technology |
| Document Number | Custom |
| Revision | 1.0 |
| Date | Monday, April 06, 2020 |
| CPU Platform | INTEL LGA1200 (Comet Lake) |
| PCH / Southbridge | B460 |
| EC / KBC | ITE 8686 |
| EC/KBC Package | LPC I/O ITE8688 |
| Audio Codec | Realtek ALC887 |
| BIOS / SPI Flash | BIOS (128M) |
| BIOS Flash Capacity | 128M |
| RAM Type | DDR4 |
| RAM Architecture | DDR4 DIMM X 1, DDR4 DIMM X 1 |
| RAM Quantity / Slots | DDR4 DIMM X 1, DDR4 DIMM X 1 |
| LAN IC | REALTEK 8111G |
| WiFi / WLAN IC | R_USB31 (NA) |
| HDMI Level Shifter | HDMI (MASK) |
| Card Reader IC | it8892e-na/"]IT8892E (NA)[/URL] |
| Charging IC | isl95866-vccgt-iron/"]ISL95866 VCCGT-IRON[/URL], ISL95866 VCORE-IRON, ISL95866 PWM-IRON |
| Power IC(s) | RT8068A_VPP, RT8237_DDR_BEAD, RT8237_PCH-BEAD, RTD2168 - DP to VGA - IC |
| GPU Type | Integrated (CPU) |
| Graphics Architecture | INTEL LGA1200 (Comet Lake) |
| Revision | 1.1 |
| Date | Monday, June 22, 2020 |
| CPU Platform | Intel LGA1200 (Comet Lake) |
| LAN IC | Realtek 8111G |
| RAM Type | DDR4 |
| RAM Architecture | DDR4 DIMM X 1 / DDR4 DIMM X 1 |
| RAM Quantity / Slots | 2 |
| Charging IC | ISL95866 |
| Power IC(s) | ISL95866 VCCGT-IRON / ISL95866 VCORE-IRON / ISL95866 PWM-IRON / RT8237 / [URL="https://dr-bios.com/components/power-ic/rt8068a-vpp/"]RT8068A_VPP[/URL] |
| HDMI Level Shifter | RTD2168 |
| Card Reader IC | IT8892E |
| WiFi / WLAN IC | Realtek 8111G |
B460
PCH / Southbridge
8686
ALC887
DDR4
8111G
LAN Controller
R_USB31 (NA)
WiFi / WLAN
HDMI (MASK)
Signal Conditioning IC
IT8892E (NA)
Card Reader IC
ISL95866 PWM-IRON
Charging / PD IC
ISL95866 VCCGT-IRON
Charging / PD IC
ISL95866 VCORE-IRON
Charging / PD IC
RT8068A_VPP
Power IC
RT8237_DDR_BEAD
Power IC
RT8237_PCH-BEAD
Power IC
RTD2168 - DP TO VGA - IC
Power IC
Integrated (CPU)
Graphics
Graphics
ISL95866
Charging / PD IC
ISL95866 VCCGT-IRON / ISL95866 VCORE-IRON / ISL95866 PWM-IRON / RT8237 / RT8068A_VPP
Power IC
RTD2168
IT8892E
Card Reader IC
Realtek 8111G
WiFi / WLAN
B460
PCH / Southbridge
8686
ALC887
DDR4
8111G
LAN Controller
R_USB31 (NA)
WiFi / WLAN
HDMI (MASK)
IT8892E (NA)
Card Reader IC
ISL95866 PWM-IRON
Charging / PD IC
ISL95866 VCCGT-IRON
Charging / PD IC
ISL95866 VCORE-IRON
Charging / PD IC
RT8068A_VPP
Power IC
RT8237_DDR_BEAD
Power IC
RT8237_PCH-BEAD
Power IC
Power IC
Integrated (CPU)
Graphics
Graphics
ISL95866
Charging / PD IC
Power IC
RTD2168
IT8892E
Card Reader IC
Realtek 8111G
WiFi / WLAN
