Gigabyte B550M GAMING Schematic
The Gigabyte B550M GAMING motherboard, revision 1.0, is built around the AMD AM4 CPU platform paired with the Promontory PCH. The board features four unbuffered DDR4 memory slots and utilizes an IR35201 plus IR3555 power stage for VCORE and VCORE_SOC regulation. Audio is handled by the ALC1220 HD audio codec, while networking is provided by the Realtek RTL8111EP LAN IC. The embedded controller is an IT8688E LPC SIO. The board includes a RTS5441 card reader controller and a TUSB321_A31 USB hub IC. Power management components include the RT8120D for VDDIO_MEM and the NCT3103S for DDRVTT.
Q: What is the CPU platform and PCH used on this motherboard?
A: The motherboard uses the AMD AM4 CPU platform with a Promontory PCH.
Q: What audio codec is used on the Gigabyte B550M GAMING?
A: The board uses the ALC1220 HD audio codec.
Q: What LAN IC is present on this motherboard?
A: The board uses the Realtek RTL8111EP LAN IC.
A: The board uses the IT8688E LPC SIO as the embedded controller.
| Brand | Gigabyte |
| Model | B550M GAMING |
| Document Number | B550M GAMING |
| Revision | 1.0 |
| Date | Wednesday, April 22, 2020 |
| CPU Platform | AMD AM4 |
| PCH / Southbridge | Promontory |
| Audio Codec | ALC1220 |
| LAN IC | RTL8111EP |
| EC / KBC | IT8688E |
| Charging IC | RT8120D |
| Power IC(s) | IR35201 + IR3555 |
| RAM Type | DDR4 |
| RAM Architecture | Unbuffered |
| RAM Quantity / Slots | 4 |
| Card Reader IC | RTS5441 |
| USB Hub IC | TUSB321_A31 |
