Salim Badakhshan
Gigabyte GA-H81M-D3V-JP UC Rev 1.01 Schematic
The Gigabyte GA-H81M-D3V-JP motherboard, revision 1.0, dated August 29, 2013, is built on the Intel LGA1150 platform with an H81 PCH. It features dual DDR III memory slots, each supporting one DIMM. The system is managed by an ITE8620 EC/KBC, while audio is handled by a Realtek ALC887 codec. Networking is provided by a Realtek RTL8111F LAN/WLAN IC. Power management is controlled by an ISL95812 charging IC and a 6208 power IC. The board includes a VL805 USB hub IC for USB 3.0 support. The board number is 9MH81MD2V-00-01.
A: The ITE8620 LPC I/O controller is used.
A: The Realtek ALC887 audio codec is used.
Q: What LAN IC is used on this motherboard?
A: The Realtek RTL8111F LAN IC is used.
Q: What is the charging IC on this motherboard?
A: The ISL95812 charging IC is used.
The Gigabyte GA-H81M-D3V-JP UC revision 1.01 motherboard is built on the Intel LGA1150 platform with an H81 PCH. It features dual BIOS configuration, an ITE8620 LPC I/O controller, and a Realtek ALC887 audio codec. Networking is handled by a Realtek RTL8111F LAN IC. The board supports DDR III memory across two DIMM slots. USB 3.0 connectivity is provided via a VL805 controller. Integrated graphics output is available through RGB and DVI display interfaces.
Q: What USB 3.0 hub controller is used on this motherboard?
A: The VL805 USB 3.0 hub controller is used.
| Brand | Gigabyte Technology |
| Model | GA-H81M-D3V-JP |
| Motherboard Manufacturer | Gigabyte Technology |
| Board Number | 9MH81MD2V-00-01 |
| Revision | 1.0 |
| Date | Thursday, August 29, 2013 |
| CPU Platform | Intel LGA1150 |
| PCH / Southbridge | H81 |
| EC / KBC | ITE8620 |
| Audio Codec | Realtek ALC887 |
| LAN IC | Realtek RTL8111F |
| Charging IC | ISL95812 |
| Power IC(s) | ISL95812, 6208 |
| RAM Type | DDR III |
| RAM Architecture | DDRIII DIMM X 1, DDRIII DIMM X 1 |
| RAM Quantity / Slots | 2 |
| USB Hub IC | VL805 |
| WiFi / WLAN IC | Realtek RTL8111F |
| Graphics Architecture | Intel LGA1150 |
| dGPU Chip Number | ISL95812 |
| dGPU to UMA Conversion Support | ISL95812 |
| Model | GA-H81M-D3V-JP UC |
| Revision | 1.01 |
| Date | Friday, November 08, 2013 |
| CPU Socket | LGA1150 |
| BIOS / SPI Flash | Dual BIOS |
| RAM Architecture | DDRIII DIMM X 1 / DDRIII DIMM X 1 |
| GPU Type | Integrated |
| Graphics Architecture | RGB Display / DVI Display |
9MH81MD2V-00-01
Board Number
LGA1150
H81
PCH / Southbridge
IT8620
ALC887
RTL8111F
LAN Controller
ISL95812
Charging / PD IC
ISL95812, 6208
Power IC
DDR3
VL805
USB Controller
RTL8111F
WiFi / WLAN
Intel LGA1150
Graphics
ISL95812
GPU Chip
Graphics
9MH81MD2V-00-01
Board Number
LGA1150
H81
PCH / Southbridge
IT8620
ALC887
RTL8111F
LAN Controller
ISL95812
Charging / PD IC
ISL95812, 6208
Power IC
DDR3
VL805
USB Controller
RTL8111F
WiFi / WLAN
Intel LGA1150
Graphics
ISL95812
GPU Chip
Graphics
