Schematic hp compal ls-4896p rev-0.1 odd extend board schematic
hp compal ls-4896p rev-0.1 odd extend board 1
BrandCompal Electronics, Inc.
ModelODD Extend Board
Motherboard ManufacturerCompal Electronics, Inc.
Document NumberLS-4896P
Revision0.1
DateTuesday, October 21, 2008
Board NumberLS-4896P
This Compal Electronics ODD Extend Board, documented under LS-4896P revision 0.1, is a proprietary engineering drawing dated October 21, 2008. The schematic details an optical disc drive extension board featuring two ODD connectors, JODD1 (FOX_LN11133-B001-7F_NRCONN) and JODD2 (SANTA_202001-1_NRCONN), along with SATA signal routing for data transmission. The board includes mounting holes H1 through H4 and a board identifier ZZZ1. This document is classified as confidential and proprietary to Compal Electronics, Inc., intended for internal R&D use only.
Q: What is the document number for this ODD Extend Board?
A: The document number is LS-4896P.
Q: What is the revision of this schematic?
A: The schematic is revision 0.1.
Q: What connectors are used on this ODD Extend Board?
A: The board uses a FOX_LN11133-B001-7F_NRCONN at JODD1 and a SANTA_202001-1_NRCONN at JODD2.
  • HP=1=Compal_LS-4896P_Rev-0.1_ODD_Extend_Board.pdf
