Schematic hp elitebook 8440p la-4901p rev 1.0 schematic
BrandCompal
Motherboard ManufacturerCompal Electronics, Inc.
Project CodeCartier DIS
Board NumberLA-4901P
Revision1.0
Date2009-12-01
CPU PlatformIntel CLARKSFIELD/ARRANDALE with IBEX PEAK-M core logic
EC / KBCSMSC KBC 1098
Audio CodecIDT 92HD75
BIOS / SPI FlashSPI ROM 8MB N10M-GLMP
Charging ICSLB9635TT
Power IC(s)TPA6047A
RAM TypeDDR3
RAM ArchitectureDual Channel
RAM Quantity / SlotsDDR3-SO-DIMM X 2
Thermal SensorEMC2113
Card Reader ICRicho R5C835
LAN ICIntel Hansville GbE
WiFi / WLAN ICIntel
This Compal LA-4901P Rev 1.0 motherboard schematic, dated 2009-12-01, documents the Cartier DIS platform built around Intel CLARKSFIELD/ARRANDALE processors with the IBEX PEAK-M PCH. The board utilizes an SMSC KBC 1098 EC/KBC controller and an 8MB SPI ROM (N10M-GLMP) for BIOS storage. Memory architecture consists of dual-channel DDR3 1066/1333MHz via two SO-DIMM slots. The integrated audio solution is an IDT 92HD75 codec paired with a TPA6047A amplifier. Networking is handled by an Intel Hansville GbE LAN controller. The schematic also specifies an EMC2113 thermal sensor, a Richo R5C835 card reader, and an SLB9635TT charging IC.
A: The BIOS is an 8MB SPI ROM, specifically the N10M-GLMP.
A: The EC/KBC controller is an SMSC KBC 1098.
A: The motherboard supports dual-channel DDR3 1066/1333MHz memory via two SO-DIMM slots.
Q: What audio codec and amplifier are used on this motherboard?
A: The audio solution consists of an IDT 92HD75 codec and a TPA6047A amplifier.
  • HP_EliteBook_8440P=LA-4901P_Rev_1.0_DR-BIOS.COM.zip
