HP EliteBook x360 1030 G3 DA0Y0DMBAF0 Schematic
This Quanta Computer Inc. project Y0DB, designated PIKEULT 1/9 revision 1A, is based on the Intel Cresent Bay ULT platform featuring a Broadwell U processor in a BGA1168 package. The system memory consists of two 16Gb x32 LPDDR3L/LPDDR3 modules operating at 1600MHz and 1.2V. The embedded controller is an ITE 8987 in a BGA128 package, while audio is handled by an ALC3242 codec in an MQFN package. The charging IC is an SLB9665 V2.0, and power management is provided by PS8201A and PS8330B ICs in QFN-40 packages. A RTS5237 card reader controller and an RTJ RIT8350 sensor hub are also present. The board utilizes a 10-layer PCB stack-up with specific ground, signal, and power layers.
Q: What is the project code and board number for this motherboard?
A: The project code is Y0DB, and the board number is PIKEULT 1/9.
Q: What embedded controller is used on this motherboard?
A: The embedded controller is an ITE 8987 in a BGA128 package.
Q: What type of memory is supported on this motherboard?
A: The motherboard supports LPDDR3L/LPDDR3 memory at 1600MHz and 1.2V, using two 16Gb x32 modules.
A: The charging IC is an SLB9665 V2.0.
| Brand | Quanta Computer Inc. |
| Project Code | Y0DB |
| Board Number | PIKEULT 1/9 |
| Revision | 1A |
| Date | Tuesday, October 28, 2014 |
| CPU Platform | Intel Cresent Bay ULT Platform |
| CPU Model | Broadwell U |
| CPU Package | BGA1168 |
| GPU Type | Integrated |
| Graphics Architecture | eDP/DDI |
| EC / KBC | ITE 8987 |
| EC/KBC Package | BGA128 |
| Audio Codec | ALC3242 |
| Audio Codec Package | MQFN |
| RAM Type | LPDDR3L / LPDDR3 |
| RAM Architecture | x1600MHz 1.2V |
| RAM Quantity / Slots | 2PCS 16Gb x32 |
| Card Reader IC | RTS5237 |
| Sensor Hub | RTJ RIT8350 |
| Charging IC | SLB9665 V2.0 |
| Power IC(s) | PS8201A, PS8330B |
| Power IC Package | QFN-40 |
| TPM | TP2546 |
| TPM Package | QFN-16 3x3 |
| Headphone Amplifier | HPA0022642 |
| PCB Layer Count | 10L |
| PCB Stack Up | TOP, SGND, IN1(High), IN2(Low), SGND, SVCC, IN3, IN4, SGND, BOT |
