File Request IO for Lenovo IdeaCentre 310-20IAP
CyrusCC
CyrusCC
BM6G28 & IAPLSB
Laptop Model
AIO 310-20IAP
Hi,
Please provide me the IO dump file for above AIO PC which I found 2 different MB model numbers for it (IAPLSB Rev: 1.0 and BM6G28 Rev: 1.0). The IO IC is "IT8738E" and its programmable IC is "25D05BT". I believe the dump file I have is damaged as the programmer can give me an error regarding pin 7 damages.
Regards
CyrusCC
CyrusCC
Thanks for your reply. Those files are for different models. But there has to be another 64KBit or 128KBit file for EC_Rom1 IC which is closed to the IO chip. The IO and its programmed IC are mentioned above.
Regards
CyrusCC
CyrusCC
The file you sent is for ITE8731 and not 8737E. Please check it. Also, please check the file I uploaded which I'm not sure if it's ok or not as it is only 64KB.
  • GD25D05 - EC_ROM - FR.BIN
CyrusCC
CyrusCC
I don't understand why you did it this way. you just change 1 to X for only the first part (and not both), reducing the length of the file and think it will solve the case? I am so disappointed.
