je40 acer 4750g convert to uma please help
kewl07
have already remove the gpu supply coil and re locate the resistot near the novuton ic,. still no lcd activation only power led
history of laptop is auto shut off after power on,. now it is powering on after gpu disable but n display,.
do i need to reflash the bios?
correction the model is 4755G
kewl07
here it is,. and also the coil removed and resistor relocated
hi
you must add and remove many component and part . In this model, the conversion operation is not performed by removing only one inductor. This week, a video tutorial on how to convert DIS to UMA will be published on the site.
