Unlock Bios Password lenovo 300w 4th gen
Attachment Download Access
you should run bios update
Ensure the SATA power and data cables are securely connected to the SSD and motherboard
Update Drivers:
Make sure you have the latest drivers for your SATA or M.2 chipset installed.
Hardware Troubleshooter:
Windows' Hardware and Devices troubleshooter can help identify and resolve hardware-related issues.
Initialize/Format the SSD:
If the SSD is not initialized or formatted, it may not be detected by the BIOS. Initialize and format the SSD using Disk Management in Windows.
Test in Another PC:
If possible, test the SSD in another computer to determine if the issue is with the SSD itself.
Check for Faulty Hardware:
If other troubleshooting steps fail, it's possible the SSD or motherboard hardware is faulty
CZ027
Hany
all is ok the laptop is runing good with the same ssd just i want to install windows but the bios is secure with passowrd and when i flash the bios what you send the bios see NO ssd any more its problem of BIOS
there is no other way for this !
i sent all solutions !
