Schematic lenovo n200 n440 a-note-fingerprint schematic schematic
lenovo n200 n440 a-note-fingerprint schematic 1
BrandWistron Corporation
ModelFinger Print board
Motherboard ManufacturerWistron Corporation
Document NumberSA
RevisionA3
DateFriday, September 22, 2006
EC / KBCAES1610-CDFTR-GP
EC/KBC Package71.A1610.B0U
BIOS / SPI FlashS25FL004A0LNFI-GP
BIOS Flash Exact ModelS25FL004A0LNFI-GP
BIOS Flash ManufacturerDY
BIOS Flash Capacity4Mbit
BIOS Flash Package8-pin SOIC
Charging ICAAT3221IGV-3D3-1GP
Power IC(s)AAT4610AIGV-GP
USB Hub ICSR05-1-GP
CrystalXTAL-12MHZ-9GP
This Wistron Corporation Finger Print board, revision A3, dated September 22, 2006, is a dedicated sub-board designed for fingerprint authentication. The board is controlled by an AES1610-CDFTR-GP microcontroller in a 71.A1610.B0U package. It utilizes a 4Mbit S25FL004A0LNFI-GP SPI flash memory for firmware storage. Power management is handled by an AAT3221IGV-3D3-1GP charging IC and an AAT4610AIGV-GP power switch. The design incorporates a 12MHz crystal oscillator and an SR05-1-GP USB hub IC for interface connectivity. The board features a USB header connector and includes critical layout nodes such as DRIVE_RING#, FDRV, CL33, and VDD_3.3.
Q: What is the main controller IC on this Finger Print board?
A: The main controller is an AES1610-CDFTR-GP in a 71.A1610.B0U package.
Q: What SPI flash IC is used for firmware storage?
A: The firmware is stored on a 4Mbit S25FL004A0LNFI-GP SPI flash memory IC.
Q: What power management ICs are used on this board?
A: The board uses an AAT3221IGV-3D3-1GP for voltage regulation and an AAT4610AIGV-GP for power switching.
  • Lenovo N200 N440=1=a-note-fingerprint_Schematic.zip
