In this photo , it shows how to convert motherboard Dis to UMA Lenovo Z510 (NM-A181) intel Graphic!
In this conversion you do not need to remove Graphic Chip or programming the bios !
On some occasion, the main Graphic chip fails to work; hence it’s expensive to purchase new one or replace Graphic chip. Therefore, the better choice is to remove or cut the current flow of power to the Graphic chip, most of the time they remove a coil or two coils or just they remove or lift their pins from the Ground. Even though you cannot be able to do Graphic works or game with it but you can do basic needs and save your money. In this way, repair person switch the Notebook to Intel Graphic. You can use schematic and datasheet of the pieces and by the help of below pictures; you can know how to convert Dis/UMA Graphic to Intel Graphic which is integrated in CPU! Here he has converted it by removing two coils.
Hope you Enjoy!
Hope you Enjoy!
