Technical Support macbook pro mid 2013 shutsdown after 30 minutes not overheating
kewl07
can somebody help me,. i did everything i can
reflash spi few time with clean me
tried diff ssd
the problem is the unit shuts off sundenly after 30 minutes even if the unit is not overheating
and i cannot downgrad/install older os past catalina,. it just stays on the loading bar and nothing happens.
this i a liquid damaged unit and i have replaced u7600 that is the 1.05 supply ic
tried diff ssd
i suggest you reprogram bios with 100% ok file after check motherboard and be sure have not any disconnect or water damage .
