msi megabook m620 ms-1010 rev 0c
The MSI MS-10100.CB is a motherboard designed around the Intel Socket 478 Banias CPU platform, utilizing the Intel 855GME graphics architecture and ICH4-M southbridge. System memory is provided by two DDR SO-DIMM slots. The embedded controller is an ENE 3910, and the audio codec is an ALC658. Power management is handled by a MAX1907 charger IC alongside MAX1715 and MAX1902 power ICs. The board features an RTL8101 PCI LAN controller, an R5C593-CSP277 card bus and flash card reader, and a Chrontel video bridge. Clock generation is provided by an ICS 950812. The BIOS is stored in a dedicated BIOS ROM IC. The block diagram indicates support for Mini PCI wireless, AC97 audio, USB 2.0, and ATA-100 storage.
A: The embedded controller is an ENE 3910.
A: The audio codec is an ALC658.
A: The charging IC is a MAX1907.
Q: What LAN IC is used on this motherboard?
A: The LAN IC is an RTL8101.
| Brand | MSI (Micro-Star Int'l Co., Ltd.) |
| Model | MS-10100.CB |
| Board Number | MS-10100.CB |
| Revision | 0 |
| Date | Tuesday, June 15, 2004 |
| CPU Platform | Intel Socket 478 Banias |
| CPU Socket | Socket 478 |
| PCH / Southbridge | ICH4-M |
| GPU Type | Intel 855GME |
| Graphics Architecture | Intel 855GME |
| EC / KBC | ENE 3910 |
| Audio Codec | ALC658 |
| BIOS / SPI Flash | BIOS ROM |
| Charging IC | MAX1907 |
| Power IC(s) | MAX1715, MAX1902 |
| RAM Type | DDR SO-DIMM x2 |
| RAM Quantity / Slots | 2 |
| Card Reader IC | R5C593-CSP277 |
| LAN IC | RTL8101 |
| WiFi / WLAN IC | Mini PCI |
| CLK Generator | ICS 950812 |
| Video Bridge | Chrontel |
| Audio Amplifier | CH7009 |
