Schematic MSI MS-9141 Rev 0A 0B 00b 00e 200 Schematic
Salim Badakhshan
BrandMSI (Micro-Star International)
Motherboard ManufacturerMicro-Star Int'l Co., Ltd.
CPU Platform[URL="https://dr-bios.com/components/cpu-platform/dual-prestonia-processors/"]Dual Prestonia Processors (Socket 604)[/URL]
Chipsetich4/"]Intel Placer (MCH) + ICH4[/URL]
BIOS / SPI FlashFWH (8Mbit)
Audio Codecad1885-ac-97/"]AD1885 (AC'97)[/URL]
LAN IC82551-10-100/"]Intel 82540 (Gigabit) + Intel 82551 (10/100)[/URL]
Super I/Opc87366-sio/"]PC87366 (SIO)[/URL]
Memory ArchitectureDDR DIMM x4 (Channel A + Channel B)
Expansion SlotsAGP 8X/4X + PCI 32 Slot x4
StorageIDE Primary + IDE Secondary + Floppy
USBUSB 2.0 Port x6
Document Number5544332211DDCCBBAA03
RevisionRev 00E
DateTuesday, March 18, 2003
This MSI reference schematic details a dual Intel Prestonia (Socket 604) processor workstation/server motherboard built around the Intel Placer MCH and ICH4 chipset. The platform supports four DDR DIMM slots organized as Channel A and Channel B, alongside an AGP 8X/4X slot and four PCI 32-bit slots for expansion. System firmware is stored on an 8Mbit FWH (Firmware Hub) device. Integrated audio is provided by an AD1885 AC'97 codec, while networking is handled by dual Intel LAN controllers: an 82540 Gigabit Ethernet and an 82551 10/100 Ethernet. The system also includes a PC87366 Super I/O for legacy port management, six USB 2.0 ports, and dual IDE channels with floppy support.
Q: What BIOS/FWH IC is used on this motherboard?
A: The system uses an 8Mbit FWH (Firmware Hub) device for BIOS storage.
Q: What is the CPU platform and socket type?
A: The motherboard supports dual Intel Prestonia processors using Socket 604.
Q: What LAN controllers are present?
A: The board features an Intel 82540 Gigabit Ethernet controller and an Intel 82551 10/100 Ethernet controller.
Q: What is the memory configuration?
A: The platform supports four DDR DIMM slots arranged as Channel A and Channel B.
DateFriday, February 21, 2003
PCH / SouthbridgeICH4
GPU TypeAGP 8X/4X
EC / KBCSIO (PC87366)
Audio Codecad1885-ac-97-codec/"]AD1885 (AC'97 Codec)[/URL]
RAM TypeDDR
RAM ArchitectureDDR DIMM 1, DDR DIMM 2, DDR DIMM 3, DDR DIMM 4 (Channel A & Channel B)
LAN IC82540 (Gigabit LAN)
WiFi / WLAN IC82551
This Micro-Star International motherboard schematic, dated February 21, 2003, details a dual Prestonia processor platform using Socket 604 CPUs. The platform is built around the Intel Placer chipset, consisting of the MCH and ICH4 southbridge. Memory architecture supports DDR across four DIMM slots organized into Channel A and Channel B. The system utilizes an FWH (8Mbit) for BIOS storage and an SIO (PC87366) for legacy I/O and keyboard/mouse control. Audio is handled by an AD1885 AC'97 codec. Networking capabilities include a Gigabit LAN controller (82540) and an additional 82551 LAN IC. Expansion is provided via AGP 8X/4X and multiple PCI 32-bit slots. The board also features USB 2.0 ports, IDE interfaces, floppy support, and serial/parallel ports.
Q: What is the BIOS flash configuration on this motherboard?
A: The motherboard uses an 8Mbit FWH (Firmware Hub) for BIOS storage.
A: The motherboard uses an SIO (PC87366) for Super I/O and keyboard/mouse controller functions.
A: The motherboard supports dual Prestonia processors using Socket 604.
A: The motherboard supports DDR memory across four DIMM slots, organized into Channel A and Channel B.
CPU PlatformDual Prestonia Processors
CPU SocketSocket 604
GPU TypeAGP 8X/4X
RAM TypeDDR
RAM ArchitectureDual Channel (Channel A & Channel B)
RAM Quantity / Slots4 DIMMs (DIMM 1, DIMM 2, DIMM 3, DIMM 4)
LAN IC82551-10-100-lan/"]82540 (Gigabit LAN) + 82551 (10/100 LAN)[/URL]
USBUSB 2.0 (6 ports)
IDEPrimary IDE + Secondary IDE
Parallel PortYes
Serial PortCOM1 + COM2
FloppyYes
VRM StandardVRD 9.1
PCI Slots4x PCI 32-bit slots
This MSI dual Prestonia processor motherboard uses Socket 604 with the Intel Placer MCH and ICH4 southbridge chipset. Memory architecture supports DDR in dual-channel configuration across four DIMM slots. The system BIOS is stored in an 8Mbit Firmware Hub (FWH). Onboard networking includes an Intel 82540 Gigabit LAN controller and an Intel 82551 10/100 LAN controller. Audio is handled by an Analog Devices AD1885 AC'97 codec. The Super I/O is a National Semiconductor PC87366 providing legacy I/O support including parallel port, two serial ports (COM1 and COM2), floppy, and hardware monitoring. Expansion includes four PCI 32-bit slots and an AGP 8X/4X slot. USB 2.0 connectivity supports six ports. The VRM follows the VRD 9.1 standard for CPU power regulation.
Q: What type of BIOS flash is used on this motherboard?
A: The BIOS is stored in an 8Mbit Firmware Hub (FWH).
Q: What LAN controllers are present on this motherboard?
A: This motherboard features an Intel 82540 Gigabit LAN controller and an Intel 82551 10/100 LAN controller.
Q: What is the memory configuration of this motherboard?
A: The motherboard supports DDR memory in dual-channel architecture (Channel A and Channel B) across four DIMM slots.
Q: What CPU socket and VRM standard does this motherboard use?
A: The motherboard uses Socket 604 for dual Prestonia processors and follows the VRD 9.1 VRM standard.
Motherboard ManufacturerMICRO-STAR INT'L CO., LTD.
DateTuesday, June 17, 2003
CPU PlatformDual Intel Prestonia Processors (Socket 604)
Audio CodecAD1885
LAN IC82551
SIO (Super I/O)PC87366
This MSI motherboard is designed for dual Intel Prestonia processors using Socket 604, paired with the Intel E7505 Placer chipset (MCH) and an ICH4 southbridge. The system memory architecture supports DDR DIMMs across two channels (Channel A and Channel B), with four DDR DIMM slots available. Onboard audio is provided by an AD1885 AC'97 codec. Networking capabilities include dual LAN controllers: an Intel 82540 Gigabit Ethernet controller and an Intel 82551 Fast Ethernet controller. Storage connectivity includes IDE ATA133 and Serial ATA (SATA1 and SATA2). The BIOS is stored on an 8Mbit Firmware Hub (FWH) component. The system is managed by a National Semiconductor PC87366 Super I/O controller, which handles legacy I/O, hardware monitoring, and floppy drive support. Expansion slots include three PCI 32-bit slots and an AGP 8X/4X slot.
Q: What is the BIOS flash IC type used on this motherboard?
A: The BIOS is stored on an 8Mbit Firmware Hub (FWH) component.
Q: What LAN controllers are used on this motherboard?
A: This motherboard uses an Intel 82540 Gigabit Ethernet controller and an Intel 82551 Fast Ethernet controller.
Q: What Super I/O controller is used on this motherboard?
A: The Super I/O controller is a National Semiconductor PC87366, which integrates hardware monitoring and legacy I/O functions.
DateMonday, April 28, 2003
GPU TypeAGP 8X/4X
Audio CodecAD1885
LAN IC82551-10-100-lan/"]82551 (10/100 LAN)[/URL]
RAM TypeDDR
RAM Quantity / Slots4 DIMMs (DDR DIMM 1, DDR DIMM 2, DDR DIMM 3, DDR DIMM 4)
SIO / Super I/OPC87366
This MSI motherboard is designed for dual Intel Prestonia processors using Socket 604, paired with the Intel Placer MCH and ICH4 southbridge. The platform supports DDR memory across four DIMM slots, organized into Channel A and Channel B. Graphics connectivity is provided via an AGP 8X/4X slot. The system firmware is stored on an 8Mbit FWH (Firmware Hub) flash device. Networking capabilities include an onboard 82540 Gigabit LAN controller and a separate 82551 10/100 LAN controller. Audio is handled by an AD1885 AC'97 codec. The LPC bus connects to an NS/PC87366 Super I/O controller, which manages legacy interfaces including parallel port, serial ports (COM1 and COM2), floppy, keyboard, and mouse. Additional expansion is provided through four PCI 32-bit slots, and the board includes USB 2.0 ports and IDE interfaces.
A: The motherboard uses an 8Mbit FWH (Firmware Hub) flash device.
A: The board features an 82540 Gigabit LAN controller and an 82551 10/100 LAN controller.
Q: How many DDR DIMM slots are available and what is the memory architecture?
A: There are four DDR DIMM slots organized into Channel A and Channel B.
ChipsetIntel Placer Chipset
MCHPlacer MCH
GPU TypeAGP 8X/4X
Audio CodecAD1885
RAM TypeDDR
RAM Quantity / Slots4 (DDR DIMM 1, DDR DIMM 2, DDR DIMM 3, DDR DIMM 4)
Super I/OPC87366
DateTuesday, May 13, 2003
This Micro-Star International motherboard is designed for dual Intel Prestonia processors using Socket 604, paired with the Intel Placer chipset consisting of the Placer MCH and ICH4 southbridge. The board supports four DDR DIMM slots across two channels and features an AGP 8X/4X graphics interface. The system BIOS is stored in an 8Mbit FWH flash device. Onboard networking is provided by an Intel 82540 Gigabit LAN controller and an Intel 82551 10/100 LAN controller. Audio is handled by an AD1885 AC'97 codec, and system I/O management is performed by a National Semiconductor PC87366 Super I/O controller. The board also includes six USB 2.0 ports, IDE primary and secondary channels, a floppy controller, parallel port, and two serial ports (COM1 and COM2).
A: The board uses an 8Mbit FWH (Firmware Hub) flash device for BIOS storage.
A: The motherboard supports dual Intel Prestonia processors in Socket 604.
Q: What chipset does this motherboard use?
A: The board uses the Intel Placer chipset, consisting of the Placer MCH and ICH4 southbridge.
Q: What are the onboard LAN controllers?
A: The board features an Intel 82540 Gigabit LAN controller and an Intel 82551 10/100 LAN controller.
  • MSI MS-9141 Rev 00b-3-17-1400 Schematic.pdf
  • MSI MS-9141 Rev 0A Schematic.PDF
  • MSI MS-9141 Rev 0B Schematic.pdf
  • MSI MS-9141 Rev 200 Schematic.pdf
  • MSI MS-9141 Rev V1.0-5-9-1400 Schematic.pdf
  • MSI MS-9141-5-16-1000 Rev 00E Schematic.pdf
