Schematic MSI MS-95A5 Rev 0A 10A 1B 100 Schematic
Salim Badakhshan
BrandMS-95A5
ModelGEM318 Guardian Enclosure Management Controller
Board NumberAMS-95A5 SCSI BACKPLANE
Revision0A
DateFriday, November 21, 2003
Document NumberPCB9522-10A
CPU Platform1U SAF-TE SCSI BACKPLANE
The MS-95A5 GEM318 Guardian Enclosure Management Controller is a 1U SAF-TE SCSI backplane board, revision 0A, dated Friday, November 21, 2003. The board number is AMS-95A5 SCSI BACKPLANE, with document number PCB9522-10A. The platform is designed for SCSI backplane management, featuring SCSI LVD connectors, IDE and FDD connectors, a power connector, hardware monitor, and video connector. The board includes logic ICs such as 74HC08 and 74HCT14 for signal management and LED control.
Q: What is the board number and revision of this SCSI backplane?
A: The board number is AMS-95A5 SCSI BACKPLANE, revision 0A.
Q: What is the document number for this board?
A: The document number is PCB9522-10A.
Q: What is the platform architecture of this board?
A: The platform is a 1U SAF-TE SCSI BACKPLANE.
BrandMSI
ModelMS-95A5
Motherboard ManufacturerMSI
Board NumberMS-95A5
Revision1.0
Date星期二, 四月 06, 2004
Document NumberMS-95A5
TitleGEM318 Guardian Enclosure Management Controller 1U SAF-TE SCSI Backplane
PCB NumberPCBX_95A5-1.0
SCSI ConnectorSCA1 Y SCSI80-P
SCSI ID ConfigurationID0, ID1, ID2, ID3
Motor Spin FunctionMotor spins up at D.C. power on; Motor spins up only when START UNIT command is received; Motor spins up at D.C. power on after a delay in seconds 12 times the value of the numeric SEL_ID for the SCSI device
Differential Pair Impedance122 ohm +/-10 %
Power ConnectorJPWR1 D1x4, JPWR2 D1x4
Front Panel ConnectorJ3 HEADER 22X2
IDE and FDD ConnectorJ9 CONN2X8
SCSI LVD Connectors4
Hardware MonitorYes
Video ConnectorYes
Power IC(s)U7 SI9424DY
Logic IC(s)U1 7407-SOIC14, U17 74HCT14, U18 74HC08, U19 74HCT14
The MSI MS-95A5, revision 1.0, is a GEM318 Guardian Enclosure Management Controller 1U SAF-TE SCSI backplane, dated Tuesday, April 6, 2004. The PCB is identified as PCBX_95A5-1.0. It features a single SCA1 Y SCSI80-P connector and four SCSI LVD connectors. The backplane includes a hardware monitor and a video connector. Power is supplied via JPWR1 and JPWR2 D1x4 connectors. The design incorporates a U7 SI9424DY power IC and logic ICs including U1 7407-SOIC14, U17 74HCT14, U18 74HC08, and U19 74HCT14. The SCSI ID is configured via ID0, ID1, ID2, and ID3. The motor spin function supports power-on spin-up, START UNIT command spin-up, and delayed spin-up based on the SCSI device SEL_ID. Differential pair impedance is specified at 122 ohm +/-10%.
A: The board number is MS-95A5, revision 1.0.
Q: What type of SCSI connector is used on this backplane?
A: The backplane uses a single SCA1 Y SCSI80-P connector.
Q: How many SCSI LVD connectors are present?
A: There are four SCSI LVD connectors.
Q: What power IC is used on this backplane?
A: The power IC is U7 SI9424DY.
BrandMS-95A5
ModelGEM318 Guardian Enclosure Management Controller 1U SAF-TE SCSI Backplane
Board NumberMS-95A5
Revision10A
Date星期四, 四月 15, 2004
PCB NumberPCB95A5-10A
CPU PlatformGEM318 Guardian Enclosure Management Controller
EC / KBCGEM318
Charging ICSI9424DY
Power IC(s)7407-SOIC14
LAN IC74HC08
WiFi / WLAN IC74HCT14S
The MS-95A5 is a GEM318 Guardian Enclosure Management Controller 1U SAF-TE SCSI backplane motherboard, revision 10A, dated April 15, 2004. The board number is MS-95A5, with a PCB identifier of PCB95A5-10A. The platform is built around the GEM318 enclosure management controller, which also serves as the EC/KBC. Power management is handled by a SI9424DY charging IC and a 7407-SOIC14 power IC. The board utilizes 74HC08 and 74HCT14S logic ICs for LAN and WLAN interface control. The backplane supports SCA and LVD SCSI connectors, with integrated SAF-TE SCSI backplane management functionality.
Q: What is the board number and revision of this motherboard?
A: The board number is MS-95A5, revision 10A, with PCB number PCB95A5-10A.
A: The EC/KBC is the GEM318 Guardian Enclosure Management Controller.
A: The charging IC is a SI9424DY.
BrandMS-95A5
Board NumberMS-95A5
Revision1.0
DateMonday, July 16, 2007
TitleMS-95A5 SCSI Backplane
EC / KBCgem318-guardian-enclosure-management-controller/"]GEM318 Guardian Enclosure Management Controller[/URL]
Charger Architecture+12V CHARGE(L), +5V CHARGE(L), OPT 3.3V CHARGE(L)
Power IC(s)U1A 7407-SOIC, U1B 7407-SOIC, U1F 7407-SOIC
LAN ICU7 SI9424DY
Card Reader ICU18A 74HC08, U18B 74HC08, U18C 74HC08, U18D 74HC08, U17A 74HCT14S, U17B 74HCT14S, U17C 74HCT14S, U17D 74HCT14S, U17E 74HCT14S, U17F 74HCT14S, U19A 74HCT14S, U19B 74HCT14S
The MS-95A5 is a 1U SAF-TE SCSI backplane board, revision 1.0, dated July 16, 2007, with PCB identifier PCBX_95A5-1.0. The board is built around the GEM318 Guardian Enclosure Management Controller, serving as the primary enclosure management and SCSI backplane controller. Power delivery architecture includes +12V CHARGE(L), +5V CHARGE(L), and OPT 3.3V CHARGE(L) rails. Logic-level signal processing is handled by multiple 74HC08 and 74HCT14S ICs. The board features a SI9424DY MOSFET for power switching and a 7407-SOIC buffer/driver for signal conditioning. The design supports SCA and LVD SCSI connectors with integrated drive activity LED control and spindle synchronization.
Q: What is the primary controller IC on this backplane?
A: The GEM318 Guardian Enclosure Management Controller.
Q: What is the board revision and date?
A: Revision 1.0, dated Monday, July 16, 2007.
Q: What power rails are available on the power connector?
A: +12V CHARGE(L), +5V CHARGE(L), and OPT 3.3V CHARGE(L).
Q: What MOSFET is used for power switching?
A: U7 SI9424DY.
  • MSI MS-95A5 Rev 0A Schematic.pdf
  • MSI MS-95A5 Rev 1B Schematic.pdf
  • MSI MS-95A5 Rev 10A Schematic.pdf
  • MSI MS-95A5 Rev 100 Schematic.pdf
