Salim Badakhshan
MSI MS-95B6-8Y810 Rev A00 Schematic
This Dell PowerEdge 4600 server memory card schematic, document number 8Y810 revision A00 dated April 15, 2003, details the Jaguar DDR 6BE memory subsystem. The board number is 8Y811 with PWA 8Y813 and assembly drawing 8Y809. The architecture supports up to twelve DDR DIMM slots (DIMM_J1 through DIMM_J12) organized across four memory cards: REMC DP0, REMC DP1, REMC DP2, and REMC DP3, each housed in a 225 PBGA package. Each memory card connects via separate I2C buses with specific addressing. The design includes a CLKBUF0 clock buffer, VREF and VTT regulation, and 2.5V regulation. The stackup specifies an 8-layer PWB with outer layers of 1.5 oz Cu and inner layers of 1.0 oz Cu. The memory card is designated as Jaguar DDR 6BE, with each DIMM memory card supporting multiple data and strobe lines.
Q: What is the board number and schematic number for this Dell PowerEdge 4600 memory card?
A: The board number is 8Y811, the PWA number is 8Y813, the assembly drawing number is 8Y809, and the schematic number is 8Y810 revision A00.
| Brand | Dell |
| Model | PowerEdge 4600 |
| Motherboard Manufacturer | Dell Computer Corporation |
| Board Number | 8Y811 |
| PWA Number | 8Y813 |
| Assembly Drawing Number | 8Y809 |
| Schematic Number | 8Y810 |
| Revision | A00 |
| Date | 4/15/03 |
| CPU Platform | Jaguar |
| RAM Type | DDR |
| RAM Architecture | 6 DIMM |
| RAM Quantity / Slots | 12 (DIMM_J1 through DIMM_J12) |
| Memory Card Connectors | DIMM_J1, DIMM_J2, DIMM_J3, DIMM_J4, DIMM_J5, DIMM_J6, DIMM_J7, DIMM_J8, DIMM_J9, DIMM_J10, DIMM_J11, DIMM_J12 |
| Memory Card Type | Jaguar DDR 6BE |
| Memory Card A | REMC DP0 |
| Memory Card B | REMC DP1 |
| Memory Card C | REMC DP2 |
| Memory Card D | REMC DP3 |
| Memory Card Package | 225 PBGA |
| Clock Buffer | CLKBUF0 |
| I2C Address DIMM_J1 | 1010 000xb |
| I2C Address DIMM_J2 | 1010 001xb |
| I2C Address DIMM_J3 | 1010 010xb |
| I2C Address DIMM_J4 | 1010 011xb |
| I2C Address DIMM_J5 | 1010 100xb |
| I2C Address DIMM_J6 | 1010 101xb |
| I2C Address REMC DP0 | 1110 1Y0xb |
| I2C Address REMC DP1 | 1110 1Y1xb |
| PWB Number | 8Y811 |
