Technical Support Onboard RAM Disable help Lenovo V15-ADA GV451&GV551 NM-D151
LowVoltage
Hello!
I need help with onboard ram disabling on Lenovo V15-ADA laptop.
Motherboard model is GV451&GV551 NM-D151.
I have boardview ( attached it here ), but don't have schematic. Don't know what elements to lift/move to disable ram.
  • NM-D151 Rev10.tvw
rafetorpak
UPDATE:
I figured it out, in case someone has the same problem, all that needs to be done is RC1606 needs to be moved to RC123 position, for Samsung memory.
Aynı sorun bende var ama dediğini yaptım görüntü alamadım, farklı bir bios yazmama gerek var mı ?
