Technical Support Toshiba E45 CA10SU/CU RTC BATTERY LOW
Ipart
Hi
What may be the problem that the RTC BATTERY LOW message keeps popping up. The board does not have a CMOS battery. The main battery was replaced. Can You help me?
Hi
A series of new motherboards The RTC voltage enters the PCH directly from the laptop battery. If your board is also from this series of motherboards, you should check the output voltage of the battery, which is 3.2 volts, and sometimes the non-original battery may not have this voltage. The battery does not communicate properly.
